- April 25, 2024 at 6:53 pm #36520
In Diablo 4, you will find a lot of different items that will differ from each other not only by tier but also by statistics, bonuses, and special properties. To make it easier for you to choose the right equipment, you should compare the currently used one with that you want to use before equipping it. In this guide, we will show you how to realize this process.
To compare Diablo 4 items, simply open your inventory or stash, hover over the item you want to compare with an item of the same type currently in use, and press Shift (PC), Triangle (PS), or Y (Xbox). The stats of two items will appear on the screen – information glowing green means that the specific stats increase.
However, this way you often have to spend a lot of time eyeballing two items to see which one is actually more valuable to you overall. On the one hand, it’s nice that the real value of the game’s gear isn’t limited to a simple Item Power Level number. On the other hand, the process of diligently comparing all the loot you pick up to see which stats are more valuable to you can quickly grow tiresome.
If you don’t want to do that, there is a better way. First off, open your Diablo 4 settings. From there, go to the “Gameplay” tab. In that tab, you should see an option for Advanced Tooltip Compare.
This feature shows you exactly what you’re gaining and losing by swapping items. It might not mean much in the early game, but it will become incredibly valuable in the late game when optimizing your character can mean the difference between life and death.
More importantly, this tooltip shows you that quite a lot of that “useless” gear you were picking up is incredibly valuable. You might think that anything that isn’t a Legendary or better item should be ignored, but that’s not always true. Some Yellow items feature insane stat buffs that can be further enhanced by adding a Legendary Aspect to the gear or “rerolling” one of the item’s lesser stats at the Occultist.
In addition, when comparing items, it is worth paying attention to the following things:
Weapon type: make sure it’s the type of weapon you want to use. Weapon type affects its effectiveness, attack speed, and damage. For example, bows are faster than crossbows but usually have slightly lower damage per shot.
Stats: When comparing armor pieces, pay attention not only to the armor stat but also to those stats that are used by your character. For example, for a Rogue, it will be Dexterity, and for a Barbarian it will be Strength.
Bonuses and special properties: higher-tier items have additional bonuses that, for example, add points to certain types of skills or release special effects when a certain condition is met – after using a skill, after taking damage, etc.That is all you need to know about comparing D4 Items and tips. We hope this will help you get more fun in the game! By the way, if you want the best items quickly, we recommend you buy D4 Items directly on U4gm. No matter how rare it is, you can buy it here!
- April 29, 2024 at 12:00 pm #36590
As a discerning player, security and reliability are paramount to me, and Zoome Casino upholds the highest standards in this regard. They prioritize the safety of personal data and ensure the integrity of gameplay. Additionally, clear and concise game rules and conditions mitigate misunderstandings, fostering transparency and trust.
