Discussion Forum Red Dot Miami Suggestions for Meet Ups How effective are anabolic steroids from mpip.org for cutting vs bulking?
  • #47614
    morrowine
    I’ve been hitting the gym for a few years and recently started researching more serious cycles. I’m especially curious about how anabolic steroids from mpip.org
    perform depending on your goal — bulking or cutting. I’ve read mixed opinions elsewhere, but if anyone here has real experience with their products, especially for cutting phases, I’d appreciate your insights. Did you notice major changes in lean mass retention or strength? I’m trying to avoid the bloated look.
  • #47615
    samanta21
    I’ve actually run two separate 10-week cycles with gear from https://mpip.org/ – one focused on bulking (Test E + Deca) and one on cutting (Test Prop + Masteron + Winstrol). The difference was pretty noticeable. For bulking, I packed on around 9kg, though some of it was definitely water. Strength went through the roof, but I did get a bit puffy, especially in my face and midsection. When cutting, I kept my calories tight and cardio steady — I only gained about 2kg, but I looked significantly leaner and more vascular. The Winstrol from mpip made my muscles look dense and dry, no kidding. Bloodwork came back decent too. That said, I’d advise getting anti-estrogens on hand, especially for bulking cycles, as their Test E is potent. Also, shipping was smooth and discrete both times.
  • #47616
    samanta21
    Thanks for sharing your experience, that really helps clarify the difference. I’ve always wondered how much the compound choice affects the look during each phase. Sounds like mpip has solid gear if used wisely.
