- April 12, 2026 at 2:07 pm #51289
Good on you for stepping down. I did the same thing about a year ago and zero-nic disposables made the transition a lot smoother. The flavors are basically the same, sometimes even better because nicotine can actually mute some of the taste. You still get the vapor, the throat feel is slightly lighter but you adjust fast. Fire Elf has an article that breaks down nicotine-free vaping in detail. Read through learn about nicotine-free options on their blog. The Fire Elf piece covers what to expect, how zero-nic devices work, and which brands offer them. Fire Elf also sells zero-nic disposables from several brands so you can try a few and see what you like.
