Discussion Forum Leica S System S Lenses Anyone using Variable NDs on the S lenses?
  • #2105
    Marc,
    Everyone who was on the New England Fall trip with David worked with ND and variable ND. They were so valuable, every one bought into David’s system. I suspect he will be answering you too. But from a user perspective there was no vignetting issue with the 35 using screw in polarizing and ND filters. We also used David’s “external” system for ND and variable ND, with no vignetting and which can be viewed here:
    http://www.dalephotoanddigital.com/_e/Kits/product/68-885603/Schneider_Landscape_Control_Kit_4x5_65.htm
    The plus of this system is one set of filters can be used on all lenses with a simple adaptor. The glass quality of the filters is great. Totally different than plastic or resin.
    If you use it on a 120mm, you need a filter spacer which Josh sold me.
    Hope this helps
  • #2106
    Cam Garner
    I use the Singh-Ray variable ND filters all the time. They make a thin version in additional to their regular version and neither causes vignetting on the 35mm.
  • #2113
    I used the Kenko NDX Variable ND filter on our New England Fall Foliage workshop with excellent results. Check out this thread for a few images.
  • #2840
    woodyspedden
    Cam Garner;1983 wrote: I use the Singh-Ray variable ND filters all the time. They make a thin version in additional to their regular version and neither causes vignetting on the 35mm.
    My experience as well. Singh Ray is a great company and Ray Singh a true gentleman
