Discussion Forum General Discussion General Leica Discussion Сan someone help me find a DeLonghi coffee machine manual?
  • #49851
    Monica00
    A while back, I got a used Delonghi coffee machine. Even though it’s in good shape and has all the parts, it didn’t come with the original box or manual, just the warranty card. I know how to use it, but I’d like to see what other features and cool stuff it has. Does DeLonghi have a general instruction manual for all of their espresso machines? Is it necessary to know the specific model of the machine?
  • #49853
    Jordan22
    Hi there, I think you need to know the exact model name. Have you checked the bottom of the machine? There is usually a sticker with the necessary model and serial number. If not, it will complicate matters a bit. I recommend looking for the manual here: https://manualmachine.com/delonghi/“>https://manualmachine.com/delonghi/ . All Delonghi appliance instructions are collected there. First, check if you know the model name. If not, you can determine the coffee maker series by its external features. For example, if it has a built-in coffee grinder, then it is most likely from the La Specialista series. If it has a square design, it is probably from the Stilosa series, etc.
  • #49854
    Jordan22
    Hi there, I think you need to know the exact model name. Have you checked the bottom of the machine? There is usually a sticker with the necessary model and serial number. If not, it will complicate matters a bit. I recommend looking for the manual here: https://manualmachine.com/delonghi/ . All Delonghi appliance instructions are collected there. First, check if you know the model name. If not, you can determine the coffee maker series by its external features. For example, if it has a built-in coffee grinder, then it is most likely from the La Specialista series. If it has a square design, it is probably from the Stilosa series, etc.
